Can I put a 20r chain on a 22r? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2005, 10:42 AM   #1 (permalink)
View TheModifier's Photo Gallery
What does it take to put a 20r chain on a 22r? I have a complete 20r and a 22r. I would use the 20r, but it is beyond repair.
Dan
TheModifier is offline   Reply With Quote
Old 08-14-2005, 10:50 AM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
I believe the 22r has a taller block than a 20r. Did you swap heads or anything?
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 08-14-2005, 10:53 AM   #3 (permalink)
No, the 22r is complete, and I am getting ready to put it into my 80 GT. I want to replace the timing chain, and I figure I would upgrade at this time.
Dan
Old 08-14-2005, 11:08 AM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
I made a frankenstein motor once but had to use the block specific chain.
雄のハヤブサ
Old 08-14-2005, 12:49 PM   #5 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
Dan
It all depends on what year the 22R you have is. In 83 I beleive Toyota went to a single chain. In 85 Toyota made the 22R a different deck heighth. the 81 and 82 22R's had a double row chain just like the 20R's. Basically if you have a double row chain on your 22R then it will fit on your 20R. Just make sure you have the double row gears and cover.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 08-14-2005, 12:52 PM   #6 (permalink)
View foompla's Photo Gallery
this is a silly idea, but do timing chains come apart lke bicycle chains?
foompla is offline   Reply With Quote
Old 08-14-2005, 12:55 PM   #7 (permalink)
SCCA Tech Services
NO and I don't know why you would want to take the chain apart anyways.
Brian Harmer
Old 08-14-2005, 01:00 PM   #8 (permalink)
first thing i said was that it was a silly idea. and the idea wouldve been to make it longer.
Old 08-17-2005, 09:05 PM   #9 (permalink)
My 22r has a single chain, and I would like to put the dual on, but dont want to pull it all apart for it not to work.
Dan
Old 08-17-2005, 09:32 PM   #10 (permalink)
SCCA Tech Services
Dan
If you get a double row cover, chain, cam gear, and crank gear it will work. People have done it many of times.
Brian Harmer
Old 08-18-2005, 10:15 PM   #11 (permalink)
Cool, my 20r has the cover, and I will buy a new chain and gears to be safe.
Dan
Old 08-20-2005, 08:27 AM   #12 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
^ you should also swap that 20r head on to it too. surpise hotwheel hasnt said that.
^ and leaving it that way!
