White smoke - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2005, 11:47 PM   #1 (permalink)
touringcamry's Avatar
Gameroom cash: $510425
White smoke
My Celica is blowing white smoke out of the tail pipe. This I'm guessing is a water leak somewhere.
Does that mean I have to replace the head gasket? How much would this run for a 3SGTE or is this a difficult job that I might be able to do myself?
The car has a front mounted intercooler so I guess that's a little less items to remove...
2007 Camry 2.4L 5M
Old 08-15-2005, 02:27 AM   #2 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
Yeap, sounds like a head gasket, and it's a pretty big job but not too bad. Check out the procedure in the manual.
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 08-15-2005, 03:55 AM   #3 (permalink)
Boooost
turbo_GT's Avatar
View turbo_GT's Photo Gallery
try putting some lucas in there...might get it out..
Your signature is in violation of rule #4.
http://www.toyotanation.com/forum/t20118.html
turbo_GT is offline   Reply With Quote
Old 08-15-2005, 10:03 AM   #4 (permalink)
Holy crap...I was looking ini the Haynes manual for my Camry and wow...it's a big job to say the least.
If I bring this to a shop, would it be a good idea to have them change the timing belt and water pump since they're ripping the engine apart.
2007 Camry 2.4L 5M
Old 08-15-2005, 08:30 PM   #5 (permalink)
Greed ruined tuning
View 93toyota's Photo Gallery
Yea probably a good idea. I say do it, unless you wanna do it yourself.
93 Celica ST 5spd bone stock
93toyota is offline   Reply With Quote
Old 08-24-2005, 05:56 PM   #6 (permalink)
View celica supra 83's Photo Gallery
bring it to the shop dude,and yes get your water pump assembly replaced at the same time ,they have a habit of letting go.You don't wanna do it yourself if your not 100% sure of what your doing,(were to put silicone,torque spec ect...)
celica supra 83 is offline   Reply With Quote
Old 08-25-2005, 12:14 AM   #7 (permalink)
Noob :-)
View ST185's Photo Gallery
Check if you see can oil in coolant or coolant in oil (milky stuff in the oil).
Do you lose coolant? Does it boil? Does your car overheat?
Check all that and check the compression before you blame the HG.
White smoke can cause by blown oil seal in the turbo.
93 ST185
ST185 is offline   Reply With Quote
Old 08-25-2005, 02:07 PM   #8 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
Yep.
Also, you could have bubbles in the coolant [real large ones], and it can be pressurized even after it cools down [pull of the cap and you'll hear it release the pressure]
alltracman78 is offline   Reply With Quote
