Originally Posted by 90celicaGT-S
hey insanity what other mods have you done to get to 300 last time i looked ur car was pretty stock.
Well I`ve had her off the road for two weeks now
. had a new stainless exhaust fitted, got a stainless 3" decat pipe (a right pain in the arse to fit) which I had polished internally and gasflowed, an Apexi AVC-R boost controller (fitted and getting set up tomorrow all being well). Boost set to 1 bar at the moment, will be upped to 1.1 bar when things have settled down a bit. Throttle body cleaned and polished, turbo overhauled and gasflowed a little, new plugs. chargecooler cleaned out, inlet manifold cleaned up internally, new brake flexi`s, new rear wheel bearings. full fluid change, all oils and coolants, new carbon fibre radiator ducting to help keep things cool.
The decat pipe makes a huge difference, the car revs much more freely, turbo spools up alot quicker, sounds alot more throaty, now spits flames from the exhaust on both up and down gear shifts
and the extra boost .......well you can guess what that does. next will be new brakes all round and a water injection kit
probably running more than 300bhp but thats a conservative guesstimate. after that will be new suspension and eventually a new ECU. but a bit at a time, you cant rush these things. looking forward to the test run at the weekend, watch out scoobies, here comes insanity
