fuel problem 86 gts?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-20-2005, 09:32 PM   #1 (permalink)
View wanagofastgts's Photo Gallery
i have an 86 celica gts just got it its been up on blocks for about 4 years i put a new batt. in it and about 5 gallons of gas and it wont start if i shoot a little gas in the intake it fires right up and sound great motor only has about 55 thousand on it any ideas fuel pump? fuel pump relay? or would it be the EFI relay please help or how can i test the pump?
wanagofastgts is offline   Reply With Quote
Old 08-21-2005, 10:31 AM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
the gas in the tank probably turned into a solid
Old 08-22-2005, 11:52 AM   #3 (permalink)
So what can i do? Is the pump shot also if the fuel has turned solid? do i need a new tank? Is it possible there is no power to the pump because of a bad relay? Is there any way to tell if the relay is working will it make any noise with the key on? is there any way to test the pump cause a new one is over 2 hundred dollers thanks!
Old 08-22-2005, 01:19 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
get the back seat out and pull the pump, see if the gas has eaten up everything and stinks like hell
