Easiest way to 200whp turbo charged. - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2005, 11:21 PM   #16 (permalink)
N/A bites
Tercel GTS's Avatar
You're still lacking 40hp from the original request of 200. But that is a very good suggestion. It's also available with a 6speed. I believe a 20valve would also be in the same range.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 08-25-2005, 12:33 AM   #17 (permalink)
All it takes is MONEY
View marcuslogsdon's Photo Gallery
lol we could go back and forth on this subject for months!!!!! you are right that is about 40hp under what he wanted.... but if he took off the super charger and put a turbo on it.... he could run upwards of 15-17psi and still have it reliable. thoes motors can hold some serious boost numbers. i still think...buying a ST....swapping to the 4agze.....and putting a turbo(instead of the supercharger) would be less money than buying the gt or gts......and swapping in the 3sgte. the gt and gts's are generaly more money... and the 3sgte motor is more expensive than the 4agze. if he were looking for a motor that had HUGE potential not to mention 200hp stock and money wasnt an issue i would deflinatly go with the 3sgte but that is not the case.
marcuslogsdon is offline   Reply With Quote
Old 08-26-2005, 06:18 AM   #18 (permalink)
N/A bites
Tercel GTS's Avatar
very well said!
if he were looking for a motor that had HUGE potential not to mention 200hp stock, i would deflinatly go with the 3sgte
^my reason of choice also...
雄のハヤブサ
Old 08-26-2005, 11:38 PM   #19 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
Tercel GTS, just to clarify, the 6-speed only came on the later blacktop models, never the 4AGZE. You can get it with LSD though. (By the way, that's the E58 tranny which internally is the same as yours).
And, the 3SGTE will still be cheaper and easier to get to 200hp than installing a 4AGZE and THEN building a turbo system for it.
-Doc
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 08-27-2005, 08:45 PM   #20 (permalink)
N/A bites
Tercel GTS's Avatar
15? You might want to read some of the threads in the MR2 section.
雄のハヤブサ
Old 08-27-2005, 08:49 PM   #21 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
yeah, it can go well above that....
alltracman78 is offline   Reply With Quote
Old 08-27-2005, 11:09 PM   #22 (permalink)
The Mad Scientist
The stock 3SGTE ECU even has maps in it for 16 psi
(They're locked out unless you hack the ECU though.)
Old 08-29-2005, 04:41 PM   #23 (permalink)
View letheal's Photo Gallery
honestly. if you can boost a d series honda motor over 200hp you can boost a 7. its all in the tuning. get yourself a nice plx wideband or a zetronics. dont run an fmu. 200hp isint shit, that motor will take it. PS, you guys refrencing the amount of boost a motor can handle are retards. it depends on the size of the compressor housing and how many CFM's a turbo flows at a certine presure. if you threw a big fatty sc61 on a 3sgte and ran 15 psi its not going to be the same as that dinky ct26. also, ive seen 400hp made on a stock internal 3sge. NOT 3sgte. running mega squirt and a btm for retard. i made 300 on my 3sge at 13psi with an sc61 runing megasquirt. shit i made 230 on a d16z6 honda motor and thats open deck alumium block sohc thin rods and tin can pistons.... so some of you shouldent talk unless you've done it and have a clue 3sge's are a HELL of allot cheeper than 3sgte's too.
letheal is offline   Reply With Quote
Old 08-30-2005, 09:10 AM   #24 (permalink)
Gameroom cash: $147537
^The 7A-FE was done and blown at 13PSI.
Old 08-30-2005, 12:00 PM   #25 (permalink)
what turbo, what tuning. how many cfms was the 13 psi at, did it blow from detonation?
Old 08-31-2005, 10:04 AM   #26 (permalink)
View oneof81's Photo Gallery
Originally Posted by Turbo_Kay
Looking into a 1994 ST/GT Celica ( probably ST ).
Which is the cheaper/easier way to go to 200whp?
You KNOW that once you have 200 whp you WILL want more. Your best bet is to buy my car!
'93 ST185 bone non-stock
'04 Solara SLE V6
oneof81 is offline   Reply With Quote
Old 09-02-2005, 05:23 AM   #27 (permalink)
View lumbercis's Photo Gallery
I agree. sell whatever you are driving now and buy an alltrac.
j.
lumbercis is offline   Reply With Quote
Old 09-02-2005, 09:00 AM   #28 (permalink)
The Other White Meat
terrastrife's Avatar
buy a gen 2 camry and put a 3sgte in
terrastrife is offline   Reply With Quote
