Which is the cheaper/easier way to go to 200whp? Turbo charging stock 7afe or swapping? I Haven't looked into swaps yet and I can't seem to find someone who's priced both.
if you want 200 whp turbod, get a gt. you could spend the money turboing a 5sfe, and make it have over 200 with good tuning. or you could do a 3sgte swap on it. either way, youd make over 200 whp. but i dare say, youd be hard pressed convincing a 7afe over 200 without some serious dime.
93 toyota mark II tourer V
1jz-gte twin turbo goodness!
93 toyota scepter turbo stored back in the states!
*in loving memory rapeacivic*
By far, your best bet is to swap ina 3S-GTE.
That'll give you 180-190whp with just IntEx.
Then turn up the boost like 5 psi and you're putting down well over 200.
Maybe cams too for another 20-30hp.
Then F&I and some more psi and you'll be flying.
You should get a GT/GTS.
ST have smaller front brake and rear drum.
GT/GTS is 4 disc and have sway bars.
Turboing the 5S to 200WHP will not cost much less then a 3S swap.
Why ask a question then argue with the correct answer? Can you boost a 7a to 200hp, sure! Will it last the rest of the year, doubt it! Can you swap in a 3SGTE, sure! Will it last with proper maintenance for a few years, of course!
You decide. Tell you what though, I'm not putting a 3SGTE in a tercel just to say it's in there. I want POWER! And a lot more than you can safely get from any e or a series.
Period.
Cheapest, easiest is 100 shot nitrous. Engine "Gone in 60 second".
Just turbo the 7A and watch it die or turbo with nitrous. Engine will die "Fast and Furious".
'92 GTS 3sgte w/LSD, 7th Gen GTS Gunmetal rims.
Salon Spa Software for all your management software needs. http://salonspasoftware.com
what about the 4agze motor guys? its already supercharged... bolts right into the ST (which is lighter than the gt or gts) that swap wouldnt be very expensive if you do it yourself. and hey if you dont like the super charger take it off... put a turbo on it... or twin charge it. if i ever do anything (motor wise) to my 91 ST it will be the gze swap!!! that answers "eaiser" and "cheapest" (assuming that you want to be able to drive the car for over a year and have that kind of HP!!!!! what does every one think?
