86 gt-s idol problems!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2005, 10:07 PM   #1 (permalink)
repo94's Avatar
View repo94's Photo Gallery
I have a 86 gt-s and it has idol problems. It's really hard to start in the morrining, when i finally get it to run. i have to kind of keep giving it gas untill it warms up some. then it will idol. the next problem is that the idol changes. sometimes it will be 1000 and then you drive for a little while and when you push in the clutch, it will be 1800. Or it will bounce from 1000 to 1800 for about 10 sec. and then idol at 1800. It's kind of all over the place and i don't know where to start. I've clean'd the throttle body, inspected all the vacumm lines, i've even check'd the cruise unit to make sure it wasn't binding up the throttle cables! Can anyone help me with this??????????
repo94 is offline   Reply With Quote
Old 09-04-2005, 12:41 AM   #2 (permalink)
View letheal's Photo Gallery
sounds like your idle air control valve is going out. it sucks too because there expensive as hell.. gotta love the nippon denso parts
letheal is offline   Reply With Quote
Old 09-04-2005, 06:30 AM   #3 (permalink)
repo94's Avatar
ok, could anyone tell me off the top of there head where this is,and what the easiest way to get to it is?Is there a way to check this?
Old 09-04-2005, 09:09 AM   #4 (permalink)
its on your throttle body and should look somthing like this
keep in mind thoes are honda iacv's but yours looks genraly the same
Old 09-04-2005, 09:24 AM   #5 (permalink)
Mad Aussie Toy Owner
toyboyracer's Avatar
View toyboyracer's Photo Gallery
I had a very similar problem on my 1987 Mitsubishi Magna, it was the damn a/c compressor.
Made it a pig to start (as it was seizing) & would clutch & declutch sometimes & make the engile idle way too fast. Some sort of solenoid inside of the compressor crapped out.
Some people are like slinkies,,,,Not really good for anything,,,,
But they still bring a smile to your face when you push them down a flight of stairs
Unfortunately evreyone has an opinion [q] ME [/q]
"The Thunder From Down Under"
http://www.camcrew.com.au
toyboyracer is offline   Reply With Quote
Old 09-04-2005, 09:34 AM   #6 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273421
View REN69's Photo Gallery
Try adjusting the "idle" screw first, here's something I'll never get tired of posting over and over and over again (SEARCH would have showed you the same) on how to get rid of the up and down idle.
With the car on, find the idle screw; with a phelps screw driver turn the screw counter clockwise until you reach a steady idle speed (1800-2000rpm or so) let it run for a few seconds (10 the most) and then turn it clockwise slowly to turn the idle speed down until you reach 800-1000rpm which is the normal idle speed for 4cyl motors.
Old 09-04-2005, 10:25 AM   #7 (permalink)
repo94's Avatar
i'am not that stupid, i did try to adjust the idol screw. i think it's the idle air valve, that really makes since to me. I don't believe it's the a/c. I never use it and it doesn't make any noise. Thanks for the help. I'll let ya know
