A Comment, & A Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-08-2005, 01:17 AM   #1 (permalink)
Heavy Sleeper
View 3SGTE@daSpeedof's Photo Gallery
Gen5 A Comment, & A Question
Ok, I had a spare fuel rail that came with my car, and I want to know what green top injectors are rated at? Are they stock 4th gens injectors, I know 5th gens have yellow tops so what are these?
As well the fuel line coming off of my 3sgte motor has been cut the end that goes to the fuel filter, I want to know if its possible to swap that fuel line from my old 5th gen fuel rail, and use that with my new motor.
Swap update
Only good news on my swap is that I have changed my cam seals, front crank seal, and rear main seal. I've also hooked up my tranny, input shaft, and starter. Next up is to fix the fuel line, put on the timing belt & adjust the timing, drop the motor. So CLOSE Yet So FAR, any more recommendations before I put it in.
I will post the complete build up when I'm done, As I've primed the car, will be swapping out the suspension, redoing the interior, swapping in a 3sgte, getting paint sometime soon hopefully, but getting my car running is my top priority. Look for more to come soon.
'92 GTS 3sgte w/LSD, 7th Gen GTS Gunmetal rims.
Salon Spa Software for all your management software needs.
http://salonspasoftware.com
3SGTE@daSpeedof is offline   Reply With Quote
