Brake problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-10-2005, 03:33 PM   #1 (permalink)
Scoobie Killer
View Insanity-74's Photo Gallery
Brake problems
I have this awfull clicking noise that seems to be coming from my passenger side rear wheel, it only happens at slow speeds, or should I say its only noticable at slow speeds, it coincides (sp) with the rotation of the wheel, it dosnt happen all the time, its worst early in the morning and when the car has had chance to warm up, it dispapears when light pressure is applied to the foot brake but not when I pull the handbrake on. I have checked th back of the studs for clearance..everything is OK, I have new pads on, new discs, had the wheel bearing changed, had the handbrake shoes changed, had the oil in the diff changed. What on this earth could it be? I`m at a total loss.
Living the dream
Insanity-74 is offline   Reply With Quote
Old 09-11-2005, 10:00 AM   #2 (permalink)
Rick89GTS's Avatar
View Rick89GTS's Photo Gallery
Clicking noise is usually associated with worn CV axles.
Also, was the wheel bearing lock nut torqued to spec? I've known guys who didn't torque to spec and chewed up a new wheel bearing in no time.
Rick89GTS is offline   Reply With Quote
Old 09-11-2005, 10:11 AM   #3 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
You had the wheel bearing changed AFTER the noise started, and it's still making it?
alltracman78 is offline   Reply With Quote
Old 09-11-2005, 01:10 PM   #4 (permalink)
Rick89GTS's Avatar
Wonder if it's something simple like a bent pad-wear indicator...?
Old 09-11-2005, 02:41 PM   #5 (permalink)
Alltrack Wannabe
or heat shield...
dunno.
Old 09-11-2005, 04:01 PM   #6 (permalink)
Scoobie Killer
Well after much head scratching and tinkering I took her for a blast - (after racing a 1986 911 carrera 2) the clicking was much worse....limped home and stripped off the CV boot, after a generous squirt of WD40 half the universal joint fell out in bits....."poo" I thought...time for a new axel...thanks for the help hopefully thats the end of it.
Living the dream
Old 09-13-2005, 02:00 AM   #7 (permalink)
Rick89GTS's Avatar
At least a rebuilt CV axle doesn't cost too much...
