Originally Posted by touringcamry
Can you post some more detailed instructions? My Celica has code 71 and I'm not sure how to go about cleaning this thing out.
How much is the EGR valves from the dealer?
EGR and gasket was $172 and they are the cheapest of the 3 local one for me. Marina Del Rey.
I just went to check the vaccum and I think I punched a hole in the diapham with the screwdriver when trying to acuate the darn thing. Looks like I will be getting the new one after all. I could not find any hoses that were knocked off, damn did it again.
The dealer told me to replace the egr modulator first and its a $65 part. Might consider that.
I unscrewed the two bolts holdiing the throttle cable on and releasted the cable, it snaps right out and moved it out of the way so I could unscrew the copper tube at the block. I think it is a 23 mm. Couldn't get to the one the conects directly to the egr. I removed the gas temp sensor that's screwed into the egr after disconnecting the wire to it. There are two nuts(12mm) that holds the egr to the throttle body which need to be removed. It just lifts back and then up and out. Mine had lots of carbon build up and I was able to get it out but I did screw up I think by punching a hole in the rubber diapham. I was able to push the diaphargm up and hold it in place by putting my finger over the smallhole on top. Hmmm, maybe I just need a new gasket, leaking vacuum somewhere.
I used the gasket remover sold by the same company that sells all those different types of liquid gasket, getting old can't remember the name. Sprayed and soaked and acuated numereous times and then cleaned it all out with wd40 and some compressed air. It was messy.
I see you are in socal so maybe when i figure mine out and if you live somewhat close I could help you a little. I have the '91 factory manuals.
