1988 toyota celica - Bezel removal how to - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-13-2005, 09:47 PM   #1 (permalink)
View usmc's Photo Gallery
in need of information on how to remove the Bezel from a 1988 toyota celica gt. i need to get it off to replace the a/c, heatr & clock componet. any info on how to fix the a/c controler would be appreciated. this is the contoler with the push buttons. thanks for any & all replys!
usmc is offline   Reply With Quote
Old 09-14-2005, 12:17 AM   #2 (permalink)
Rick89GTS's Avatar
View Rick89GTS's Photo Gallery
The bezel is easy to remove; just find all the screws, including the center arm rest console, glove box and any overlapping trim pieces.
The A/C controller can be resoldered from the backside. The connections develop cracks with time and age and you end up with intermittent heat or AC.
Follow this thread: http://www.toyotacelicaonline.com/bo...ghlight=heater
Rick89GTS is offline   Reply With Quote
Old 09-14-2005, 09:55 AM   #3 (permalink)
thank you for your advice & go to thread! i have another control coming & will try the soldering on the old one when i have it replaced. i also had to hit the dash to make the a/c work but then the heater went out so the soldiering deal sounds about right. 1988 celica gt 60k
any idea on the expected life span of the timing belt?
