93 celica gts help. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-16-2005, 03:19 PM   #1 (permalink)
gts all motor.. hopefully
View 5thGENcelicagts's Photo Gallery
Gen5 93 celica gts help.
alright, well i have a 93 celica gts.. i was wondering if i can get any real power out of the 5sfe without turbo charging it and just running it all motor. any suggestions will be appreciated. thnx in advance
5thGENcelicagts is offline   Reply With Quote
Old 09-16-2005, 05:55 PM   #2 (permalink)
gt2 coming soon
View rdcel's Photo Gallery
well
i got a 92 gts all i could suggest is light flywheel exhaust intake and motor work the normal things for a all motor job.im gonna make my gts a gt2 just easier on me and less money
rdcel is offline   Reply With Quote
Old 09-17-2005, 12:07 AM   #3 (permalink)
Gameroom cash: $147537
High compression piston, P&P, custom cam shafts, lighten everything, stand alone ECU.
I'm building one, got 11.0:1 piston and P&P. Still looking for cams. Webcam have a set but I'm trying to see if I can find local in Toronto.
And yes, it'll be cheaper and more power with a 3S-GTE swap.
Old 09-19-2005, 12:07 AM   #4 (permalink)
yeah i know the swap would be cheaper then doing all that, but thats what everyone has done, also 5sfte has been done too, im still pretty new to this site but i havent come across a thread where someone just went all motor and i would like to do that.. ive been thinking about the swap but if your talking cheaper, then turbo charging my 5sfe right now would be a lot cheaper right?
Old 09-19-2005, 09:29 AM   #5 (permalink)
Yea turbo is cheaper and more protential in the long run.
NA will get you around 200HP for $3000-$5000.
Turbo will get you 400HP+ if you keep on spending.
This is the cost for my build, in canadian dollar:
Old Engine: $300
P&P and rebuild: $1500
11.0:1 piston: $800
Cams: $900 estimate
I'm lucky to get 200HP on crank.
A 3SGTE swap will get 200HP crank without mods and cost around $1500.
Old 09-19-2005, 09:40 AM   #6 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
What would be the potential with a 3S-GE? How difficult would that swap be?
2007 Camry 2.4L 5M
Old 09-19-2005, 12:14 PM   #7 (permalink)
About the same. The 3S-GE rev higher and can get pass 200HP crank. It'll drop in with ECU and wiring.
Old 09-19-2005, 01:21 PM   #8 (permalink)
thanks for the help guys.. i guess im going to try just turbo charging my 5sfe, just to clarify ive heard that the 3sgte turbo manifold bolts on to the 5sfe.. is it a direct bolt on or will i have to make any mods?
Old 09-19-2005, 01:34 PM   #9 (permalink)
Direct bolt-on.
Old 09-19-2005, 01:55 PM   #10 (permalink)
alright thank you, could you also help me out with one more thing, could you list all parts i would need for the turbo kit, i know its on several threads here but i would just like one whole complete list so i can start my hunt for everything i would need, and also an estimated time of the install
Old 09-20-2005, 07:41 AM   #11 (permalink)
View p0rshman's Photo Gallery
Gen5
Hi.i have the compleate list of all parts you need ,drop me a email p0rshman@bellsouth.net and i will try and email the list to you .Jamie
p0rshman is offline   Reply With Quote
