1990 GTS Vacume Diagram help (melt down) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-21-2005, 09:44 AM   #1 (permalink)
View rslbbl's Photo Gallery
I need help sorting out vacume hoses, does anyone have a diagram that I can view?
Thanks!
rslbbl is offline   Reply With Quote
Old 09-21-2005, 07:40 PM   #2 (permalink)
Snafu's Avatar
View Snafu's Photo Gallery
Which section of the engine do you need the diagram for? There should be one under your hood. If you have a Hayne's manual or Chiltons, there should be one in there.
Celicatech.com has the Toyota BGB online, here's a quick link for the emissions system -
http://www.celicatech.com/93rmsour/1...lica/ec/ec.htm
Hope that helps, good luck.
4AFTE running 8psi... 10 psi in the works
Snafu is offline   Reply With Quote
Old 09-22-2005, 09:54 AM   #3 (permalink)
Thanks snafu!
that is a great link, I now have access to a good manual. I had an engine fire and I have replaced all the wiring under the hood, now I am working on the vacume hoses. I already started the car however it does not run correctly, it is very hard to start takes several tries to get it to start up. I belive it is because I did not get the vac hoses hooked up correctly (I hope). I now have a good manual to refer to.
