Worth It? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-21-2005, 03:49 PM   #1 (permalink)
Post Hoc Ergo Propter Hoc
Bishop13's Avatar
View Bishop13's Photo Gallery
Question Worth It?
I've found a 1990 Celica All Trac for sale for $5000 w/ 121k miles on the ticker. According to the guy that's selling it, he's installed an HKS turbo timer, Greddy blow-off valve, and an ACT clutch, as well as changing the timing belt, water pump, spark plugs (Denso iridiums), radiator, thermostat, and water hose. The only problem is that he says the car still overheats occationally. What are your views on this? Blown/leaking headgasket? Is $5k worth it for this car? Here are the pics he sent me:
Capitalization is the difference between helping your uncle Jack off a horse, and helping your uncle jack off a horse
1997 Toyota Camry LE / 2001 Land Rover Discovery II / 2006 Audi A4
http://www.flickr.com/photos/henryenriquez/
Bishop13 is offline   Reply With Quote
Old 09-21-2005, 07:33 PM   #2 (permalink)
Snafu's Avatar
View Snafu's Photo Gallery
I would for sure do a compression test first to make sure it's not a headgasket. Overheating could be a number of things.
Check the condition of the radiator. It's going to be difficult, but it would be everything from air in the system, a bad tstat, a bad radiater fan, or worse... the head gasket. Bring a compresion test with you when you look at it.
4AFTE running 8psi... 10 psi in the works
Snafu is offline   Reply With Quote
