Of course a shop is going to tell you you need new shifter cables! Did you do all of those things I posted above? I think YOU should take a look at them.... that's right, it's best for you to check them because you're not trying to screw yourself out of 500 dollars CDN. Look at it and make that's the problem.
If it is the shifter cables, call up the junkyards around town. After that, go to local parts shops, and if all else fails.... wait 3 weeks.
-Colin
4AFTE running 8psi... 10 psi in the works
