Suspension help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2005, 08:17 PM   #1 (permalink)
All it takes is MONEY
View marcuslogsdon's Photo Gallery
Gen5 Suspension help
Hey guys. I have a '91 ST and im looking for struts and springs. I had my mind set on a Eibach's sportline springs but when I contacted KYB they said they don't reccomend them because they lower the car too much causing the struts to possibly bottom out. what kind of springs and struts are you guys running and how do you like them. I would like to get it down to the ground as far as i can SAFLEY!!!!
marcuslogsdon is offline   Reply With Quote
Old 09-24-2005, 06:01 PM   #2 (permalink)
Anyone?
Old 09-25-2005, 11:06 AM   #3 (permalink)
GT-i Crew
lcarocha's Avatar
View lcarocha's Photo Gallery
If you plan on lowering the car to the max you will have to use Koni Sports Adjustable shocks, they are the only ones who will be able to handle the shorter springs and not bust.
I have Eibach Prokit (1.5) with Bilstein shocks and the suspension is soo tight that I', going back to regular springs this week (roads are really shit around here lately). Don't get me wrong, on recently paved roads this combo is great but roads here are getting worse and worse each day, until the govenmente fixes them I'll be riding in OEM springs
Luis C.
92 Celica GT-i (ST182)
2nd Gen 3S-GE
Caracas, Venezuela
http://www.cardomain.com/id/luis_c
lcarocha is offline   Reply With Quote
Old 09-25-2005, 12:25 PM   #4 (permalink)
Snafu's Avatar
View Snafu's Photo Gallery
As stated, the Sportlines are just a bit too much for the KYB GR-2's.
I would go with the Koni adjustables, and if you do, you will need to modify your rear strut housings to accept the Koni shock.
http://celicatech.com/forums/showthread.php?t=6031
That's how you modify the strut.
Good luck,
CT
4AFTE running 8psi... 10 psi in the works
Snafu is offline   Reply With Quote
