Backup Lights are stuck on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-24-2005, 03:42 PM   #1 (permalink)
View 92 celica's Photo Gallery
On my 92 Celica, I just replaced the slave cylinder and now my backup lights are stuck on. Not sure if these are related. Not sure where to start for backup light problem. Any suggestions???
92 celica is offline   Reply With Quote
Old 09-24-2005, 05:49 PM   #2 (permalink)
All it takes is MONEY
View marcuslogsdon's Photo Gallery
is it an auto or stick? check out your backup light switch it should be located around the shifter it may be shorted out.
marcuslogsdon is offline   Reply With Quote
Old 09-24-2005, 08:03 PM   #3 (permalink)
It is a stick. I took the boot cover off and looked around, but don't think I saw a switch. Do you know what I should look for?
Old 09-24-2005, 10:52 PM   #4 (permalink)
you are looking for some kind of switch that is triggered when you shift into reverse. check the transmission, look at the linkage. something electrical trips that switch to cause the back up lights to come on. If you dont have a manual i would suggest getting one. if you dont use it this time you will use it some other time. if you find something that looks like a switch get out your multimeter. switch it to continuity. if there is continuity your switch is shorted. you can also test this by pulling the plug on the switch. the lights should go off it is the correct switch. Im not sure about this transmisson but some have thermocouplers (thermometers) to help diagnose mechanical problems. dont get confused they may look alike. they may not. also... is your check engine light on?
