Cannot shift into gear! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2005, 04:46 PM   #1 (permalink)
Toyota Junkie!!
View SLC Punk's Photo Gallery
My Celica ST185 has been acting up lately. It started when I noticed that it was hard to shift on my way to work. When I started it to go home, I couldn't get it into gear. If I turned the car off, put it in gear, then turned it on, I could go, and when I pressed in the clutch, it felt like it was still engaged (the engine would bog down or stall). Once I was in 1st, with some work, I could get it out of gear then rev the engine and drop it into 2nd. So in my mind I was thinking it was the slave cyl.
I replaced the slave cylinder and bled the system. The fluid was dirty so I bled out all of the old fluid. I took it for a drive and it shifted great. I parked it in my garage, when I started it 2 days later, the same problem, it wouldn't shift into gear. I started it and turned it off a bunch of times, sometimes it would shift into gear and other times it wouldn't shift. So now I am thinking that it is the clutch master. I just replaced it, bled the system and took it for a drive. It was shifting great. I was messing around with the clutch while driving to see and the clutch was doing its job. I stopped the car and turned it off and on a few times. About a block away from my house, I turned off the car and started it, now it won't go into gear again. But this time, I could shift it into 3rd, but it wasn't easy to get it into gear. Another thing that is different this time is when I push in the clutch (driving in gear) and pressed in the gas, I the clutch would disengage (since the revs went up and it stopped accelerating).
The clutch is about 15 months old with less than 6k miles on it. It was replaced at a toyota dealership. I called them and they said that it was out of warranty (1 year or 12k miles whichever is first).
What can it be?
1997 Toyota 4Runner V6 SR5 4X4
-TRD Supercharger-TRD Tranny Cooler
-265/75/16 Michelin LTX AT-PP 1 inch lift springs
-Deckplate mod w/amsoil
1993 Camry V6 XLE *SOLD*
-Intake
1992 Toyota Celica All Trac (ST185) 64,000 original miles
- Intake
- Upgraded CT 26 w/46 trim
- 16in wheels
- Stage II clutch
- Boosting @ 11.5 psi
My 4Runner and Celica site
SLC Punk is offline   Reply With Quote
Old 11-25-2008, 07:57 PM   #2 (permalink)
View jim9's Photo Gallery
My 94 Celica is having a simliar problem.... Car wont go in gear, but while i had the car jacked up i can go in any gears. I try bleeding many times and no changes. Ill probably try change the slave cylinder next. Anyone know what can be wrong, because i can shift in any gear and drive it while car is lifted up on jack. Clutch is not even near 2k miles yet. MAybe hydralic oil/gear oil. anyone?
jim9 is offline   Reply With Quote
Old 11-25-2008, 08:41 PM   #3 (permalink)
just a nobody
How many miles on the car? Where does the clutch engage as far as how the pedal is related to the floor board? Does it make any noise when you try to shift gear?
N.E.O.
Old 04-02-2009, 06:57 PM   #4 (permalink)
View brutalpizzadude's Photo Gallery
mine did this for a year. i kept puting gear oil in it everytime i changed oil. put 50000 miles on it till shit cable snaped
brutalpizzadude is offline   Reply With Quote
