There are a few "off" brands that sell them online for the 4AFE in a celica. Everywhere else you look, you're going to find one for a Corolla. They'll fit, but you'll need to go to an exhaust shop to have them mate it to your exhaust. Of course, if you weld, you won't have to worry about that.
As far as the suspension goes, what type of setup are you looking for? Just for looks, moderate track use or full blown track?
Your setup could range from simply KYB GR-2s and either Tein, Eibach Prokit, intrax... etc all the way to some Koni Adjustable and some high spring rate Eibach springs.
There are a lot of other parts out there such as Polyurethane bushings, strut braces, underbody braces etc. Bulletproofautomotive.com has a good selection, however their prices are a bit high and it takes a while for them to get their stuff (it's almost all from Japan).
Good luck,
Colin
4AFTE running 8psi... 10 psi in the works
