Originally Posted by tooblutacoma06
so slvr..are the LEDs you are using to build the 3-LED for the shifter the same color/brightness of the ones you used for the cluster?
They are the same color 270nm, the brightness is very close.. I will have to check the spec sheets. as you can see in the pics, there is some variation in brightnes throughout the gears. this is do to the color of the "N" and "R" and the position of "P" and "L". it looks realy good in person and there should be nothing to worry about.
I think with white LEDs the green and red colors will show up more.. something to think about.
