Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Brake components
View Single Post
Old 04-09-2007, 01:34 PM   #9 (permalink)
nodrogkam
nodrogkam's Avatar
View nodrogkam's Photo Gallery
well, u've done pretty much all you can do! good job!
I should add that while your going to bleed your brakes anyways to switch the lines, you might as well bleed more of it out so you can put some fresh fluid in. Fresh fluid has a higher boiling temp so it'll be better, plus the fluid will be cleaner, better for the lines.
nodrogkam is offline   Reply With Quote
