cruise control
I have a 96 T-100. When my cruise control went out, it was the clutch bracket. The clutch bracket (located under the steering column) begins to wear and crack where the clutch cable comes through, causing play in the clutch cable. Because of this, your cruise control sensor does not engage properly. If not repaired, your firewall wil eventually crack from excess pressure.
A new clutch bracket costs about $85. It took me 2.5 hrs to replace in my driveway - only because of cramped working area.
hope this helps. . .
