Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Will they fit ? ? ?
View Single Post
Old 04-16-2007, 09:27 AM   #2 (permalink)
kyle@tirerack
View kyle@tirerack's Photo Gallery
Both cars have similar offsets and we have used the same part numbers of certain aftermarket wheels on both cars. If the center bore of the actual wheel is larger you could likely use with a set of centering rings. There are still things such as brake clearance that I am unsure of and that could vary from wheel to wheel so a test fit would be best. The tires you have will fit the wheel without issues. Give me a call if you want to discuss the details.
kyle@tirerack is offline   Reply With Quote
