Newer engines are designed and built better then ever before (in some cases).
You should be fine to make your trip. The only reason I would consider changing your oil is to make sure you get out any small particles that might be left over from the machining process of your engine. This really shouldn't be a problem so I'd just say go ahead and take your trip and do your maint. when you return.
If you'd like to go ahead but not doing it wont hurt you either.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
