Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - no heat
Thread: no heat
View Single Post
Old 02-25-2007, 08:32 AM   #5 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Re: no heat
"89cress" <none@000.com> wrote in message
news:981650_5d3ef0b36f0cf575b5657156a25e4052@autoboardz.com...[color=blue]
> Ray O,
> I did it again last night your way, still no heat. Before when the
> heater was working, I heard some clicking sounds, like a sound of the
> solenoid clicking, or so, somewhere under the dash, on the
> driver-side, whenever I turned on the heater. Now I don't hear it any
> more, and the hear is not working. Is there really a solenoid valve,
> (besides the water valve) along the path of the heater circuit?[/color]
AFAIK, there is no solenoid valve in the path of the coolant. The coolant
flow is controlled by the hot water valve on the firewall.
The clicking sounds you are hearing are probably the actuators for the vent
dampers and blend doors or relays for the fan and resistors. Even if the
fan is not working, the heater valve should open.
Did you check to see if the heater valve on the firewall is opening and
closing? Assuming it is, then is the return hose from the heater core warm
or is it cold? Check the return hose to make sure it is not collapsed.
Ray O
[color=blue]
> "Ray O" wrote:[color=green]
> > news:979813_9e36d1862cea257a487e0b40fd0c0cdf@0000.com...[color=darkred]
> > > How do I flush the heater matrix? What is the proper way to[/color]
> > bleed the[color=darkred]
> > > system? Here is what I do: I jack the front end only up as[/color]
> > high as[color=darkred]
> > > the jacks can go, then run the engine, open the radiator[/color]
> > cap, then[color=darkred]
> > > fill with coolant when the level drops.
> > >[/color]
> > When you fill the radiator, do so with the car level, not up
> > on jacks.
> > Flush the heater matrix (called a heater core in the U.S.) by
> > setting the
> > interior temperature to full hot while flushing the rest of
> > the cooling
> > system. Because of environmental laws, I recommend having the
> > cooling
> > system professionally flushed.
> >[color=darkred]
> > > I check and I think the water valve is open or closed[/color]
> > properly.[color=darkred]
> > >[/color]
> > Set the heat to full hot and see if the heater control valve
> > opens. If you
> > are not sure if the heater control valve is moving, open the
> > hood and follow
> > the heater hose along the firewall to find the valve, and
> > watch the lever on
> > the valve move while someone changes the interior temperature
> > from full hot
> > to full cold.
> > Ray O
> > (correct punctuation to reply)[/color]
> Posted at author's request, using [url]http://www.AutoBoardz.com[/url] interface
> Articles individually verified to usenet standards. Visit URL to contact
> author/report abuse
> Thread archive: [url]http://www.AutoBoardz.com/heat-Toyota-ftopict206808.html[/url]
>[/color]
