Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - rear axle leak
Thread: rear axle leak
View Single Post
Old 05-08-2007, 02:12 PM   #2 (permalink)
xsacta
View xsacta's Photo Gallery
Originally Posted by randy69
i just purchased a 95 t100 4x4 with 230,000 with a blown head gasket. . I had the 3.4 rebuilt and replaced the rear axle bearings and seals along with all four rear u joints. my rear passenger side axle is now leaking fuild. the wheel cylinder, brakes and backing plate are dry. it is coming from a hole in the axle flange between the wheel studs and passing through a hole in the brake drum and then onto my inner rim. any one have any thoughts. thanks randy
no one seems to have an answer!!! i checked with toyota. i was told that i have a bad rear axle seal. they said it is a toyota designed so that you don't get oil on your brake shoes.
The seal can be distorted easily when it's driven in to the housing causing it to be slightly elliptical=bad. It's not hard to do that. The seal can also be damaged when inserting the axle into the housing. It's a bit awkward. Sounds like you have a redo on your hands. Take a look at the retainer ring for burrs. It should've been pressed on with a sleeve, but I've seen some use a socket=bad. Could cause a burr. BTW, the retainer should be new, not re-used as it serves as the sealing surface to the inner seal.
xsacta is offline   Reply With Quote
