Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 93 Camry overheated and won't start now
View Single Post
Old 05-12-2007, 04:00 PM   #5 (permalink)
Stillrunning
Gameroom cash: $422950
View Stillrunning's Photo Gallery
P/S and alternator belts run off crankshaft pulley. They will turn even if your TB is broken. Pull the distributor cap off, turn the key and see if the rotor turns. If it turns your TB is ok. Reason for no start may be because leaking coolant got wires wet. Strange it didn't put out hot air from heater, if thermostat is stuck that would not cause cool water in heater core.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
