How to remove Shotgun Seat? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Van Forum (1984-1989)
Van Forum (1984-1989) Specific discussion of the Toyota Van. 1984 to 1989.
Old 03-24-2008, 04:55 PM   #1 (permalink)
View Eeviac's Photo Gallery
How do I remove the "shotgun" seat in the 1986 van? I just got one, and need to get under there to get at the radiator hose to tighten the clamp.
My chilton's manual doesn't cover it. ....
Thanks in advance!
Eeviac is offline   Reply With Quote
Old 03-31-2008, 03:28 PM   #2 (permalink)
View Makelo's Photo Gallery
You mean the Passanger seat? You need to unbolt the seat rails (one bolt is located under the wheel well / top of right front tire. Then, is just a matter of unbolting everyting aroung the seat / trans lever, center console and you might have to remove the drivers seat as well (to have complete access to the engine)
Makelo is offline   Reply With Quote
Old 04-15-2008, 01:37 AM   #3 (permalink)
87 Toyota Van - 4Y
chompy's Avatar
View chompy's Photo Gallery
I think there are 14-15 bolts to remove before you can slide the passenger panel over. I was using a cordless drill, which made it a lot faster. You might have to pull up some of the carpet over the panel too if someone hasn't done this already. It opens the engine compartment up a ton.
chompy is offline   Reply With Quote
