Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Re: Oil Pressure
View Single Post
Old 03-10-2007, 06:01 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Oil Pressure
<jim_nospam_beasley@yahoo.com> wrote in message
news:1173568950.978845.179420@8g2000cwh.googlegroups.com...[color=blue]
> On Mar 10, 1:16 pm, "Ray O" <rokigawaATtristarassociatesDOTcom> wrote:[color=green]
>> <jim_nospam_beas...@yahoo.com> wrote in message
>> news:1173560281.345496.29480@h3g2000cwc.googlegroups.com...
>>[color=darkred]
>> > On Mar 4, 11:17 pm, "Ray O" <rokigawaATtristarassociatesDOTcom> wrote:
>> >> <jim_nospam_beas...@yahoo.com> wrote in message[/color]
>>[color=darkred]
>> >>news:1173078750.579371.185360@8g2000cwh.googlegroups.com...[/color]
>>[color=darkred]
>>[color=darkred]
>> >> >>news:1172355679.357802.94130@m58g2000cwm.googlegroups.com...[/color]
>>[color=darkred]
>> >> >> > My oil light goes on intermittently. When I start up, it's okay.
>> >> >> > After
>> >> >> > driving around for about 15 minutes, it comes on, sometimes
>> >> >> > steady,
>> >> >> > sometimes it flickers on and off. It was on while I was at a stop
>> >> >> > light, so I turned the engine off and back on, and the light went
>> >> >> > off.
>> >> >> > I did the same thing in my driveway when I got home and the same
>> >> >> > thing
>> >> >> > happened, it went out when I restarted the engine. I have it
>> >> >> > idleing
>> >> >> > in my driveway and the light is staying off.[/color]
>>[color=darkred]
>> >> >> Do you have enough oil? What viscosity? What brand of filter was
>> >> >> used?[/color]
>>[color=darkred]
>> >> >> At 225000 miles, you should be using 10W30 or 10W40[/color]
>>[color=darkred]
>> >> >> sd[/color]
>>[color=darkred]
>> >> > I would like to replace the oil pressure switch, but i'm not sure
>> >> > which one it is. Chilton's manual doesn't show a picture. I think
>> >> > it's
>> >> > right above the timing marks, with only one wire going to it. If
>> >> > that's it, does someone know an easy way to get it out? Chilton
>> >> > overlooks the difficulty of its location.[/color]
>>[color=darkred]
>> >> > I just changed the oil. It's 10W30, with a new filter.[/color]
>>[color=darkred]
>> >> I am not aware of any tricks to remove the oil pressure switch. Just
>> >> unplug
>> >> the wire and reach down there with the appropriate tool.
>> >> --[/color]
>>[color=darkred]
>> >> Ray O
>> >> (correct punctuation to reply)[/color]
>>[color=darkred]
>> > I finally figured out what I had to do the get the oil pressure switch
>> > out. I can get a deep socket wrench on it after I remove the
>> > alternator belt and unplug the switch. The problem I am having now is
>> > I can figure out how to disconnect the plug. There is no obvious way,
>> > and I am guessing Toyota has some special tool to press all the
>> > detents so the plug comes free.[/color]
>>[color=darkred]
>> > I'm afraid I am going to break the connector trying to get it off. Can
>> > someone tell me what the trick is? (I already broke one connector
>> > trying to figure it our, and now the detents don't hold it on any
>> > longer.)[/color]
>> If you already have the replacement switch, look at the connector. There
>> should be a tab that is perpendicular to the connector body. On the wire
>> harness side, there is a U-shaped locking connector that fits over the
>> tab
>> on the switch. Use an awl, very small screwdriver, or pick to gently
>> lift
>> the locking connector while pulling the harness off. Do not tug on any
>> of
>> the wires, pull by holding the connector body itself.
>> Ray O
> Thanks for your help, Ray. I put a sliver of metal (cut from a razor
> blade) in where I thought the catch is, but I couldn't get it to work.
> I may have to turn this over to the dealer repair shop just to get the
> plug off, and have them do the switch replacement. This switch is just
> in a place where I can't get to it or see it very well, so, without a
> proper tool, I think I am going to break the plug. I don't want to end
> up with a badly seated or loose connector when I'm done.
>[/color]
Look at another electrical connector under the hood, like for the coolant
temperature switch, EGR position sensor, etc. The connectors under the hood
all pretty much work the same way.
Ray O
