Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Toyota Highlander
View Single Post
Old 08-01-2003, 12:00 AM   #4 (permalink)
1GR-FE
View 1GR-FE's Photo Gallery
the recall was actually fuel related they need to check the position of the fuel line clamp if it is pointed up then it simply need to be rotated into the proper position, technically u are supposed to lower the gas tank but u dont need to, however if they did lower yer gas tank then an exhaust support might be loose causing yer muffler to move slightly look under the car and see if u can see any rubber exhaust mounts loose, if so take it back to the dealer and be nice about it every1 makes mistakes
1GR-FE is offline   Reply With Quote
