Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - noob: fuel filter, 95 2.2 camry, top 'banjo bolt' as jammed as...
View Single Post
Old 05-21-2007, 03:16 AM   #11 (permalink)
88 LE
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
To remove the flare nut fitting on the bottom of the filter, you can use 2 wrenches. A wrench on the fitting and another to hold the filter. Theres a hex shaped portion on the filter that you can put a wrench on.
As for the washers on the banjo bolt (top bolt), your suppose to replace them. Their a crush type washer.
"Skoolin' the unlearned!"
