Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - noob: fuel filter, 95 2.2 camry, top 'banjo bolt' as jammed as...
View Single Post
Old 05-22-2007, 01:53 PM   #14 (permalink)
Stillrunning
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Originally Posted by Heat
What size is the flare nut on the bottom?
I can confirm the flare nut is a 14mm. I think if it seems in between 13mm & 14mm it has probably been rounded by the last guy who didn't use a flare nut wrench. Don't forget to make sure you're turning it the right way. It is upside down so you would need to turn it CW as you face it from the top.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
