Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Adjusting headlights
View Single Post
Old 05-28-2007, 11:37 AM   #5 (permalink)
Tavel
View Tavel's Photo Gallery
Originally Posted by Tangerine
Which adjusting wheel did you adjust? The ones that changes the beam vertically and horizontally or the ones that changes the beam left and right? Can you take a pic of what your referring to? Did you have it parked on level surface within a few feet of a wall so you know where the beam is adjusting?
I believe I was trying to adjust the horizontal first, just to get a feel for how it works without cramping my hand reaching the bottom adjuster.
btw: I know how to properly aim headlights, I've done it numerous times. I just can't figure out how these particular adjustment mechanisms work.
This is the top adjuster (horizontal?). It only moves a few degrees in either direction. You can see my tool marks on the plastic nut.
That's the bottom one (vertical?). I don't think the screwdriver is engaging properly for some reason. The wheel won't turn at all.
Tavel is offline   Reply With Quote
