Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Tercel engine swap, possible ?
View Single Post
Old 08-05-2003, 04:06 AM   #11 (permalink)
Red93T
View Red93T's Photo Gallery
Originally posted by wedge
Like I said, you can't tell just by looking at it. Externally, they are identical. If you were to take a peek inside, you would see that the 5E-FHE has longer duration/higher lift cams (though only slightly), and the pistons are raised slightly (it has higher compression), where the normal pistons are perfectly flat.
Hi
no no, I mean the 5E-FE genenrally, how can I tell it from a 3E ?
Thanks
Dan
Red93T is offline
