FYI: Extremely bad dash rattle fixes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2005, 08:25 PM   #1 (permalink)
View drake44130's Photo Gallery
USA FYI: Extremely bad dash rattle fixes
If your dash rattles on your 04-05 Corolla or Matrix then I can tell you what I did to fix the problem.
First thing to do is remove the A-pillar trim. Then at the point where the A-pillar meets the dash you need to foam that area up. on both the dash and a-pillar. If you look at the a-pillar trim you should be able to see where the dash was rubbing up against it. You will have a hard time putting the trim back in without messing up the foam but when you do get it back in it will work wonders.
Second thing is if your rattle is coming from the inside the dash area than please use your warranty and have the dealer foam it up with as much foam as they can put in it. I did it myself and it worked great.
Third is something that I am still waiting for. Toyota has stepped up and said that they are redoing the rear motor mount. The noise/rattle you hear when you accelerate is from the rear motor mount. It is not avail. yet but Toyota is going to release it via a Technical Service Bulletin. Please keep in contact with your local Toyota dealer.
After you do this yourself, mainly because dealers dont like to mess with rattles because they dont make money on rattles, you will be extremely happy with no rattles from your dash. Check back later to find out about rear area rattles when seats are down.
drake44130 is offline   Reply With Quote
Old 11-18-2005, 09:36 PM   #2 (permalink)
IndyGo Ink
MyTrix's Avatar
View MyTrix's Photo Gallery
Good info!
Do you know what year trixs will be affected by this TSB? Both 1ZZ & 2ZZ or just one type?
My dash rattles, but only when the a/c is on. More of a buzz, actually. Moot point, I guess as I won't be needing the a/c for a while...it's like 28 here in Indy tonight...
'07 Impulse Red Tacoma TRD OR Double Cab 4x4 - ARE MX cap w/walk in door - Bedrug- TRD seat covers- Westin Steps- Sill protectors - 20% tint - Driveline & leaf spring TSBs - AFE drop in - Zaino - Lots of dog hair
'03 Indigo Matrix Xr -18/8 TSW Eurace - Sumi HTRs - Hotchkis drop - AEM CAI - 20% tint
MyTrix is offline   Reply With Quote
Old 11-19-2005, 10:20 AM   #3 (permalink)
Toyota has not released it yet but I would have to say all year matrix, and corolla's
I will find out and keep you notified.
thanks
