tire pressure lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2005, 10:13 PM   #1 (permalink)
jen
View Jenny_L's Photo Gallery
i took my car in for service.. they rotated my tires, changed my oil. thats it. when i got my car back, the tire pressure lights were on. i checked my tire pressure.. nothing wrong with it. i took it back to service, n they disabled the signal for me. 5 min later, it was turned back on again!!! how can i get things back to normal again????
Jenny_L is offline   Reply With Quote
Old 11-21-2005, 10:19 PM   #2 (permalink)
XRS
View mistamatrix's Photo Gallery
If I'm not mistaken, someone's had this problem in the past. Lemme see if I can dig it up...
mistamatrix is offline   Reply With Quote
Old 11-21-2005, 10:21 PM   #3 (permalink)
XRS
http://www.toyotanation.com/forum/t57574.html
Old 11-21-2005, 11:43 PM   #4 (permalink)
greywolf's Avatar
View greywolf's Photo Gallery
Did you try resetting it yourself? The routine is in the manual. IIRC, you turn the ignition key on then hold down the tire pressure button on the dash until the icon stops flashing.
greywolf is offline   Reply With Quote
Old 12-13-2005, 10:13 AM   #5 (permalink)
View 03matrixr's Photo Gallery
Hmmm, i have a 2003 matrix XR, does that have a tire pressure light?
03matrixr is offline   Reply With Quote
Old 12-13-2005, 11:16 AM   #6 (permalink)
XRS
^No. They started appearing in 05 and up.
Old 02-27-2006, 07:12 PM   #7 (permalink)
View Nick Krumrei's Photo Gallery
USA Tire pressure light reset, really it is good!
Hello:
I have a 2005 4WD Matrix, I drive approx 3000 miles per month and carry copier parts. I had some trouble initially with the tire pressure light. You must look at the driver door post for exact tire pressure. You will notice the fronts are 34 and the back are 32. This is not an approximation. If you set them all to 35 the light will constantly come back on. Set according to the recommendation and with the car stationary hold down the button for 10 seconds. The light will go out and will not come on again unless a problem develops. Over the last 20000 miles it has lit twice. Once was a nail, and I was able to drive to a shop before it went flat. The other was a large temp swing (55 one day -2 the next). But it has not relit for 4 months now. As has been my experience with 30 + years with many Toyota's it works just like it is supposed to.
Nick Krumrei is offline   Reply With Quote
Old 02-27-2006, 08:05 PM   #8 (permalink)
wantin150's Avatar
View wantin150's Photo Gallery
What type of system is it? Direct or passive? I would think that higher pressure wouldn't trigger the light unless it was a passive system and 1 tire was extremely low. I guess since the front and rear are different PSI, the same pressure all the way around throws off the sensors. IMO, that's about half stupid. The sensors should only monitor low pressure or that which exceeds the max sidewall stamped pressure.
wantin150 is offline   Reply With Quote
Old 02-27-2006, 08:58 PM   #9 (permalink)
View Turbolovin84's Photo Gallery
ITs a passive system, to reset the light, basically start the car, hold the tire button and the tire light will flash 3 times, once it has it has been reset and u should be worry free,
Turbolovin84 is offline   Reply With Quote
Old 02-28-2006, 04:49 PM   #10 (permalink)
EBR
View EBR's Photo Gallery
Canada
Originally Posted by Turbolovin84
start the car, hold the tire button and the tire light will flash 3 times, ,
The ECM uses wheel speed variations to determine whether or not to turn on the light. ie: a lower pressue tire will rotate more frequently in a given distance as compared to a properly inflated tire. The above statement is corect. Also the ECM has to see certain variations in the first drive cycle or the light will come back on. It has to take turning corners into consideration.
Cheers
Toyota Tech 11 years and counting...In the trade 18 years.
Current ride...02 Echo
Future ride...Idea scrapped...Selling all the parts I collected
EBR is offline   Reply With Quote
Old 02-28-2006, 08:42 PM   #11 (permalink)
wantin150's Avatar
Cheers
Why did Toyota choose a passive system instead of the better direct? (Not that you are the voice of Toyota or anything ) My car is not equiped with a system so this is just for information. Although something is better than nothing, a passive system is dangerous compared to a direct.
These systems give people a false sense of security if you aren't one to monitor your pressure yourself.
Old 02-28-2006, 08:58 PM   #12 (permalink)
EBR
Canada
04 and up 4Runners and the new Rav4 use the active system with the sensors in the wheels. This system allows monitoring of the spare as well. The other difference is that the sensors are not cheap. I think about $93.00 CAD.
Old 03-01-2006, 12:22 AM   #13 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
A passive system is cheaper to implement than a direct system. Passive system just reads the ABS sensors, something that the car already has. Direct monitoring system would require more equipment and add to the cost to manufacture and the price of the car.
2007 Camry 2.4L 5M
Old 03-01-2006, 08:22 AM   #14 (permalink)
XRS
View acrylucs's Photo Gallery
i've run my tires accidently at all different pressure, i've gone to hight too low, whatever, that light never came on.
acrylucs is offline   Reply With Quote
Old 03-01-2006, 01:01 PM   #15 (permalink)
wantin150's Avatar
The passive system monitors the wheel speed from the ABS sensors and averages them. If you have one tire at 40 and one at 20, the system reads 30 and the light doesn't activate. That is why the passive system is only marginally better than nothing at all. An active system monitors each wheel. Also, with a passive system, if all 4 wheels are underinflated, then it won't trigger the sensor.
