Hard starting
I have an 05 XR with 4500 miles on it. Recently it's gotten hard to start. It will start and die a couple of times. Then, usually on the 3rd attempt, it will start and run very rough for a few seconds before catching and smoothing out. This is at an ambient garage temperature of 55F. When leaving from work with the temp about 10 degrees it's touch and go to get it started, even with the block heater plugged in. In either situation, once it's started it runs fine. Has anyone else encountered this?
Thanks!
