XRS GPS radio reception went sour
Hey guys,
My wife has an 03 XRS that came with the radio/GPS option. The antenna is the little short unit mounted to the rear center of the roof like every other Matrix (That I've noticed).
Recently, she told me the radio quit picking up local stations and that it only gets static. It plays CDs fine, does the GPS thing fine, controlls the CD changer just fine, it just won't pick up any radio stations.
Early VW Golfs had a very similar roof mounted antenna with a small signal amplifier built into the base. These were notorious for going bad with the exact same symptoms:loss of signal reception. The common fix in the VW world is to bypass the signal amp with a little wire and a soldering iron. This gets the siganl on down the wire and to the head unit.
Has anyone heard of such problems with the Toyotas?
John
