Fuel filter anyone? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2006, 10:34 PM   #1 (permalink)
Mods??....No I'm stock
View BAM6I4's Photo Gallery
Fuel filter anyone?
I did the 30k service on my wife's 04 Matrix and no one has a fuel filter listed as a part. The dealer wasn't any help either, they are a bunch of stupid fucks. Is this replaceable just the filter or is the sending unit and the filter all one piece?
Thanks guys...
BAM6I4 is offline   Reply With Quote
Old 01-30-2006, 05:53 AM   #2 (permalink)
04 XR Manual 2WD
View ksbrace's Photo Gallery
There is a fuel filter on the pump assembly in the gas tank, and I don't see any other reference to a fuel filter in the repair manual on a quick glance.
ksbrace is offline   Reply With Quote
Old 01-30-2006, 08:48 AM   #3 (permalink)
View Clamhead's Photo Gallery
The filter part # is 23300 - 0A020. List price is approx. $35.00
It is located on the pump assy in the tank and looks like a small transmission filter. You will obviously have to pull the rear seat and pull the pump assy to put this on. There are no recommended factory service intervals, but I have it on good authority that it should last a good 100K miles.
It's a fairly substantial job, not to mention the hazards inherent in opening up your fuel tank while inside the car.
Good luck.
Clamhead is offline   Reply With Quote
Old 01-30-2006, 07:13 PM   #4 (permalink)
Frank@toronto's Avatar
View Frank@toronto's Photo Gallery
I Agree with Clamhead, it will last a long long time.
But if want to remove it then:
Remove rear seat cushion (two bolts where seat meets carpet)
You will then notice a big rubber seal (taped on the edges). It needs to pulled back
Remove two electrical connectors above fuel pump
Remove gas and vent pipes
8 bolts secure the fuel pump to the gas tank. Remove them.
Take fuel pump out and keep digging into to it to find filter cartridge.
Frank@toronto is offline   Reply With Quote
Old 01-30-2006, 10:22 PM   #5 (permalink)
Alright thanks guys, She is still getting stellar gas mileage so I won't touch it for now, but thanks for answering my questions.
Old 05-05-2006, 11:43 AM   #6 (permalink)
View Ghost's Photo Gallery
I got 170 000 Km on my 2000 corolla and I never replaced the fuel filter yet. I have inquired about it at the dealership, they stated it is a non-replacement item and the only time that the fuel filter should be replaced is when you replace your fuel pump. They also stated that it should be replaced only if you are experiencing driveability problems ....yada....yada...yada. If i were you i wouldn't worry about yet.
Ghost is offline   Reply With Quote
Old 05-05-2006, 12:43 PM   #7 (permalink)
View kwirnu's Photo Gallery
I have 107304 muiles on my 2003 corolla. It hasn't needed a fuel filter yet but I am considering replacing it soon because the car seems to be running not as smooth as it once did.
2005 avalon xl 51,000 miles
sulfur smell tsb EG039-05, timing cover and gasket tsb EG019-07, vvti oil line leak tsb EG064-05, suspension thump tsb SU005-06, transmission smoothness tsb EG033-07, ps pump and lines replaced due to leak, 18 mo clunk was loose mtr mount.
kwirnu is offline   Reply With Quote
K&N: Why take filtercharger over drop-in filter? dELuX-4x4 2nd Generation (2005+) 88 10-02-2007 01:13 AM
Want better engine performance?? CHANGE THAT FUEL FILTER! REAPER STRAIN Camry & Solara Lounge 24 01-20-2006 03:07 PM
Fuel Filter replacing was a HUGE success!! tightcamry129 Camry & Solara Lounge 13 10-21-2005 02:15 PM
Gen-5 Fuel Filter -- Losing My Mind ekpolk Hardcore Tech and Competition 8 05-16-2004 09:22 PM
Fuel filter ? tjdude Celica Forum 4 09-08-2003 08:37 PM
