how do I soften suspension - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-06-2006, 10:01 AM   #1 (permalink)
View boreal's Photo Gallery
Canada how do I soften suspension
How do I make the Matrix suspension softer? Yes softer not stiffer. I am interested in buying a base model Matrix primarily because of its size, accessibility, and cargo/trunk configuration. Problem is, the suspension is too tight and I need it to be more like a car, nice and soft. Any ideas?
How much effect will going with 14" rims have, i.e. more sidewall rubber?
Can I replace the shocks/struts with Corolla ones? Will they fit?
Anybody with experience with this?
boreal is offline   Reply With Quote
Old 02-06-2006, 07:37 PM   #2 (permalink)
RubyRed's Avatar
View RubyRed's Photo Gallery
Did you test drive a friend's Matrix or one off the dealer's lot? Dealers are notorious for putting 40-50 psi (way above recommended pressure) in the tires so the tires don't look flat after the car has sat a long time. Try riding in one with the correct air pressure. Take along a good tire gauge and make sure the COLD pressure matches what is recommended on the inside door sticker. I think you may change your tune about the Matrix being a "rough rider" after you do this.
Too old to rock-and-roll but still too young to die.
RubyRed is offline   Reply With Quote
Old 02-13-2006, 02:52 AM   #3 (permalink)
Mods??....No I'm stock
View BAM6I4's Photo Gallery
No I agree with him, my 2004 Matrix rides rough, it seems to rock back and forth front to back and its highly annoying, thank god i dont drive it full time.
BAM6I4 is offline   Reply With Quote
Old 02-13-2006, 05:37 AM   #4 (permalink)
Frank@toronto's Avatar
View Frank@toronto's Photo Gallery
Boreal,
You can always try a suspension garage and ask for an opinion.
This is the second time your asking about the 14 " rims.
Frank@toronto is offline   Reply With Quote
Old 02-18-2006, 12:29 AM   #5 (permalink)
View mikes_matrix's Photo Gallery
you cant make them softer....the corrollas wont fit at the front..the rears should....
MIKE
mikes_matrix is offline   Reply With Quote
Old 02-18-2006, 12:31 AM   #6 (permalink)
and you wont fit any 14" rims on it ....that to small and it will clearance issues with the calipers
MIKE
91-93 suspension tamalpro MR2 Forum 1 01-21-2006 09:30 PM
99 Camry Suspension atd332 Camry & Solara Lounge 10 07-29-2005 03:22 PM
Energy Suspension Polyurethane bushings JoeB Camry & Solara Lounge 3 04-18-2005 08:54 PM
Suspension setup for comfort doru Camry & Solara Lounge 12 04-05-2005 12:52 PM
