Way To Save Gas And Gain Power - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-15-2006, 01:25 PM   #1 (permalink)
Banned
View aaaslayer's Photo Gallery
Hello,
I was browsing for on ebay for stuff for my car and I came across this.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Has anyone ever dealt with one of these. IT seems like a buch of bullshit yet it's very tempting to buy because we all know we need to save at the pump, especially out here in Socal.
aaaslayer is offline   Reply With Quote
Old 02-15-2006, 02:33 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
No. It will not do anything except maybe restrict airflow. You want to save gas, get a drop in K&N filter. But that doesn't filter as well as paper filters. So it's a trade off.
Another thing you could do is remove everything that you don't need in the car to reduce the weight.
2007 Camry 2.4L 5M
Old 02-15-2006, 07:00 PM   #3 (permalink)
Frank@toronto's Avatar
View Frank@toronto's Photo Gallery
It's a miracle !!!
Come on, you would get better gas mileage by removing your spare tire and some of your seats from the car.
Frank@toronto is offline   Reply With Quote
Old 02-17-2006, 08:58 AM   #4 (permalink)
04 XR Manual 2WD
View ksbrace's Photo Gallery
If auto manufacturers could put a tiny piece of aluminum in the intake path to increase performance AND fuel economy that dramatically, it would already be there. Or, looking at it another way, if it really worked, they wouldn't sell it to consumers, but would license it to auto manufacturers and get REALLY rich. Another dead giveaway that it doesn't work is that there doesn't seem to be a white paper describing the tests, just the summary of amazing results (a test done in 1994):
http://www.fuelmiser.com/liphardt_testing.html
You could very easily get these results by doing the "baseline" test on a cold engine, and the "fuel miser" tests on a warm engine.
And here is a good article describing the effects of turbulence on fuel economy and power.
http://www.fuelsaving.info/turbulence.htm
Of particular interest is the point that increasing turbulence in the intake can slightly increase fuel economy, but CUTS power, and Mercedes Benz designers who have experimented with increasing turbulence can get perhaps a 2% increase in economy with a system that allows them to maintain power under heavy acceleration by retracting the fins at those times.
ksbrace is offline   Reply With Quote
Old 02-17-2006, 07:27 PM   #5 (permalink)
^ Isn't that similar to why Toyota uses TVIS. Is that function still in use?
2007 Camry 2.4L 5M
Old 02-17-2006, 09:00 PM   #6 (permalink)
metfan's Avatar
View metfan's Photo Gallery
The Matrix is already considered to be a fuel efficient car (STD and XR) for its type. I don't understand why you would want to save additionnal gaz as it is.
metfan is offline   Reply With Quote
Old 02-22-2006, 12:39 PM   #7 (permalink)
Banned
beacause I have the xrs with a short ram and 2.5 custom exhaust and it burns gas like a muthafuker!! its not gas efficient at all! it burns as much gas as my 92 V6 camry. Why, i dont even gun it!
Old 02-24-2006, 01:27 PM   #8 (permalink)
wantin150's Avatar
View wantin150's Photo Gallery
More air in + more air out = more power. More power usually = less fuel ecomony. That said, more air in + more air out = better fuel economy while cruising. You screwed your fuel economy the second you started bolting stuff on. There is a reason the system is restrictive from the factory.
wantin150 is offline   Reply With Quote
Old 02-28-2006, 05:13 PM   #9 (permalink)
2007 RED Camry XLE Owner
Old Dood's Avatar
View Old Dood's Photo Gallery
There also is the old saying: "If it sounds to good to be true...then it probably is..."
"We can't solve problems by using the same kind of thinking we used when we created them." Albert Einstein
Old Dood is offline   Reply With Quote
gas gauge GuJu MaN 89 Archived Corolla threads 6 11-27-2005 02:15 AM
heel-toe downshifting Morpheus Hardcore Tech and Competition 17 01-27-2004 08:30 AM
no more frowning on A/T cars! Go! project trueno General Discussion 12 12-14-2001 09:54 AM
