Synthetics allow for longer drain intervals should you want to go that route. Mobile 1 touts 15k or 1 year. Amsoil is 35K or 1 year. Synthetics outperform dino oil in all aspects, except price. If you change your oil every 3-5k with dino, you should be fine. If you go the 7500 route, IMO, I would use synthetic, especially if you tow or idle a lot. Synthetics resist sludge a lot better than dino oil also.
EDIT: I response to below, I dropped my factory oil at 1k and went Castro dino. At 5k I dropped that and went Castrol Blend. At 10K, I switch to Syntec (which is NOT full synthetic). I am currently at about 46k and will be switchingto the Amsoil 0W30 Series 2000.
