'05 Matrix - Picky CD player issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-20-2006, 01:18 PM   #1 (permalink)
mjk
View mjk's Photo Gallery
Hi,
Just bought my Matrix (gently used about 6 weeks ago. At first the factory CD player worked fine, but lately it's gotten really picky about which CDs it will play. It seems to be unable to read the disk... it just whirs them around and around and then spits them out. It's not the CDs; I've tested them in other players and they work fine. They're also store-bought, not burned. None of the disks in question have any sort of "enhancement" or copy-protection.
Has anyone else experienced/heard of this problem?
Thanks!
mjk is offline   Reply With Quote
Old 03-20-2006, 01:31 PM   #2 (permalink)
XRS
View mistamatrix's Photo Gallery
Any warranty left?
mistamatrix is offline   Reply With Quote
Old 03-20-2006, 02:42 PM   #3 (permalink)
mjk
Yes, I still have a little while left on the factory warranty. I was just hoping that someone knew some miraculous quick-fix, since getting my car into the dealership shop is both heinous and time-consuming
Old 03-20-2006, 08:11 PM   #4 (permalink)
XRS
Well I figured you could try to score a replacement instead of a quick fix which could revert at any given time.
Old 03-20-2006, 09:07 PM   #5 (permalink)
XRS
View acrylucs's Photo Gallery
picky cd reading is either a dirty/damaged laser or circuit issues. try buying a cheap cd cleaner...the ones at like walmart to see if its not a dirty laser, worst case you may lose $10. Otherwise, go to the dealer, tell them the issue, try not to get the car held overnight...it should be 30 minute replacement... (i've pulled the thing out, its not complicated to change). New stereo can never hurt!
acrylucs is offline   Reply With Quote
Old 03-21-2006, 11:25 AM   #6 (permalink)
mjk
Good points. Thank you both for your suggestions.
Old 03-24-2006, 02:02 PM   #7 (permalink)
View 1337trix's Photo Gallery
if it's still under the 60k warranty then get it replaced... had my stock radio replaced as it wouldnt eject cd's fully and i had to use my nails to pull them out.. it wasnt even questioned at the dealer
1337trix is offline   Reply With Quote
Add single DIN CD Player below existing AM/FM/Cassette Player? ganeshr Camry & Solara Lounge 22 09-12-2005 09:58 AM
new cd player for Avalon 96 suthean Audio, Video, and Security - Tech 0 04-03-2005 07:14 PM
1996 Camry CD player problem snak3uk 3rd & 4th Generation (1992–1996 & 1997–2001) 3 11-30-2003 03:58 PM
OEM CD player problem TiziteFoSheezy Camry & Solara Lounge 1 11-07-2003 10:54 AM
