Regular Unleaded vs Premium - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-06-2006, 10:24 PM   #1 (permalink)
2006 XRS Owner
matrixxrsman's Avatar
View matrixxrsman's Photo Gallery
Canada Regular Unleaded vs Premium
My apologies if this question has been asked a million times before but I have gotten conflicted information about my XRS that I purchased last week.
When I picked up my XRS my salesman told me that I only need to fill up with Premium gasoline once every couple of tanks but yet on the fuel door it clearly states "Premium Fuel Only"...Obviously Toyota knows what they are talking about when the placed that sticker there...but why would the salesman tell me something that goes against what Toyota recommends...should I stick with the Premium?
Thanks again for your help and opinions!
matrixxrsman is offline   Reply With Quote
Old 06-07-2006, 12:51 AM   #2 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
Use premium only (atleast 91). It would be foolish to run regular gas on an 11:5:1 compression ratio car. Granted it will work for daily driving in city traffic, but it would cause excessive knocking and sluggishness. It will be dangerous getting into high revs due to premature detonation of lower octane gas in the cylinder.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 06-07-2006, 05:01 AM   #3 (permalink)
XRS
View acrylucs's Photo Gallery
You wont really hear or feel any knocking because the ECU will adjust itself. thats a bad thing. It will limit the engine to avoid knocking and i've heard the way to correct it is to put back only premium and reset the ECU by unplugging the battery.
acrylucs is offline   Reply With Quote
Old 06-07-2006, 06:41 AM   #4 (permalink)
04 XR Manual 2WD
View ksbrace's Photo Gallery
I agree with the other responses. Higher compression engines like the 2ZZ require higher octane to prevent pre-ignition. On regular fuel, the engine will automatically make adjustments to prevent knocking, and those adjustments (retard timing, richer mixture) will decrease fuel economy, perhaps to the point that you might not even save any money by buying regular! As a single data point, a friend with a high compression Volvo (and a long commute) did experiments and determined that his fuel costs were nearly identical on regular and premium.
Of course, none of this is true for the 1ZZ engine. It is designed for regular, and higher octane fuel is a waste of money for that engine.
ksbrace is offline   Reply With Quote
Old 06-07-2006, 10:52 AM   #5 (permalink)
<3 lift
View XRS yo's Photo Gallery
Premium -- especially if you plan to make use of the Lift you paid extra for in your 2ZZ.
On the other hand, my gf's mom has an 05 (corolla) XRS and has used regular since day one -- but that car has barely been over 5k, so it hasnt had any problems.
But -- it costs like a 2 bucks extra to fill up with prem instead of regular. whoopie doo.
2005 Toyota Corolla XRS / GainesvilleRacing.com
XRS yo is offline   Reply With Quote
Old 06-07-2006, 01:14 PM   #6 (permalink)
2005 Matrix XRS
View D Rock's Photo Gallery
USA Dealers
Dealers often don't know what they are talking about. When I bought my Matrix, I found that I had learned more about it by researching it beforehand than the dealer knew. I tested him on a couple of things and he didn't do well. One of my checks what the fuel type on the XRS -- he told me it took regular.
Listen to Toyota, not the dealer.
D Rock
2005 Toyota Matrix XRS
D Rock is offline   Reply With Quote
Old 06-09-2006, 04:36 AM   #7 (permalink)
05 Matrix TRD
View trdbryan's Photo Gallery
Canada Fuel
Yeah if it says "premium only" you only put premium unless u want to take a big risk of damaging your engine. The cars that can run on both would say "premium recomended" that means that you will get the best performance with premium but it is not a must, "premium only" means "Premium only"
trdbryan is offline   Reply With Quote
Old 06-09-2006, 11:36 AM   #8 (permalink)
View nmehes's Photo Gallery
Canada
use any kind of gas...as long as it is PREMIUM.
nmehes is offline   Reply With Quote
Old 06-09-2006, 05:36 PM   #9 (permalink)
2006 XRS Owner
Thanks for all your help everyone...so because it accidently got one tank of regular...I should disconnect the battery to reset it?
Old 06-10-2006, 10:05 AM   #10 (permalink)
04 XR Manual 2WD
It certainly won't cause any harm to let it adjust itself over time. If you were planning a day at the race track tomorrow you would want to reset it. Otherwise I wouldn't bother.
Results! Premium vs. Regular fuel in 06 Avalon rbarbot 1st Generation (1995-1999) 5 03-30-2006 10:10 PM
Premium or Regular? wesscamrywagon Camry & Solara Lounge 19 01-10-2006 11:19 AM
Premium VS Regular Gas Zatch Archived Corolla threads 2 01-08-2005 04:07 PM
Is premium unleaded gas/petrol recommended for a gen5? SportivOZ 5th & 6th Generation (2002-2006 & 2007-2011) 36 10-24-2003 02:18 PM
Regular or premium? kileak Archived Corolla threads 14 05-30-2002 10:24 PM
