What is "Lift" - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2006, 03:39 PM   #1 (permalink)
View dalemccl's Photo Gallery
What is "Lift"
I am a prospective Matrix buyer who has been reading this forum for a week or so. I see references to "lift" and "hitting lift". Can someone explain what that means. Thx.
dalemccl is offline   Reply With Quote
Old 06-23-2006, 03:46 PM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $296373
View Buurin's Photo Gallery
That's when a Matrix (or Corolla) XRS is revved to ~6000rpm, when its high output cam profile kicks in. Expect a surge in power all the way through redline @ ~8200rpm.
You can thank the 2ZZ-GE engine and its VVTL-i system for this.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 06-23-2006, 03:49 PM   #3 (permalink)
New 2006 Corolla LE owner
View ToyotaMan1281's Photo Gallery
^^ what he said and its like a turbo setup without the turbo setup
Toyota 4 life!!
ToyotaMan1281 is offline   Reply With Quote
Old 06-23-2006, 06:19 PM   #4 (permalink)
<3 lift
View XRS yo's Photo Gallery
At ~6800rpm, you get 40 hp out of nowhere basically. Assuming of course you drive "briskly" enough and rev that high, it's a blast!
The Corolla XRS also has some suspension upgrades and a unique interior which are not found on the other Corollas.
2005 Toyota Corolla XRS / GainesvilleRacing.com
XRS yo is offline   Reply With Quote
Old 06-24-2006, 01:06 AM   #5 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
With a cold air intake, Lift is downright violent when it engages at 6700 rpm in the 2650 lbs Corolla XRS with 40 HP by 7000 rpm ( so in just 300 rpm) and holds the power up till 8400 rpm since it sucks air like crazy and the stock airbox (size of a straw) deprives it of the air needs. The intake gives all the air it needs to gobble up .Stock, the transition is relatively milder. Lift is one of the most entertaining I have experienced so far.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 06-24-2006, 03:07 AM   #6 (permalink)
Banned
View aaaslayer's Photo Gallery
what lift is IS PRETTY MUCH VTEC WITH A DIFFERENT NAME, of course it doesnt compare to vtec, vtec is way better and will never be beat. my homie takes out "sooped" up xrs's with a stock b16 and i take him out with my brand new f22 s2000!!! wutcha know bout that.
aaaslayer is offline   Reply With Quote
Old 06-24-2006, 02:44 PM   #7 (permalink)
Moderator
Originally Posted by aaaslayer
, of course it doesnt compare to vtec, vtec is way better and will never be beat. my homie takes out "sooped" up xrs's with a stock b16 .
lol....no one is even talking about Honda, yet you need to dr*g your Honda in here. Full of sh*t. b16 has nothing on the 2ZZ-GE. Nothing at all. It is a Celica GTS engine that has 170 HP stock. Unless heavily modified There is no pre-06 Civic Si (both the coupe and the hatch model) that could remotely hang with me even when I was stock after shifting into 3rd gear. Corolla XRS runs low 15s bonestock on the dragstrip and in road tests. There is your full bolt on 00 Si getting destroyed by a Corolla XRS.
http://youtube.com/watch?v=BZwrsyxrnTo&search=xrs
Here is XRS tested at 15.4@92mph:
http://www.motortrend.com/roadtests/...ecs_price.html
True, you can kill XRS or Celica GTS in your sports car S2000, but you make what 240?...looolll.. If you want to race a 2ZZ-GE then try pulling those tricks on a similarly priced 2ZZ-GE powered Lotus Elise. You will eat it's dust all day long on the straights or around a race track...lol.
p.s. Simple VTEC has no variable valve timing and only lift on the intake cam while 2ZZ does have valve timing on the intake cam and lift on both intake and exhaust cams. Honda built the K20 i-VTEC engine that has lift and vvt on the intake cam with lift on both intake and exhaust cams.
Look below for sport compact comparo of Integra Type R vs Celica GTS vs GS-R vs Prelude. The Celica GTS ran 15.3 to the Type R's 14.7 only because the Type R is rev limited at 8800 rpm while the GTS makes power until 8400 rpm:
Old 06-24-2006, 08:49 PM   #8 (permalink)
EchoHoLiK's Avatar
View EchoHoLiK's Photo Gallery
this joker makes me laugh I guess that's why Lotus went with a Toyota engine rather than a Honda one for its Elise.
vtec is way better and will never be beat....i take him out with my brand new f22 s2000!!! wutcha know bout that.
Guess it's time for someone to put you in your place. VTEC has already been beaten, if not by Toyota, then by Porsche's VarioCam Plus system. Even the base Boxster (with the same driver) will get a quicker lap time than the S2000 (proved by Top Gear), so the S2000 is nothing to cheer about.
So kiddo, sometimes it's better to be humble and keep your trap shut. But I guess you're brought up where you're taught to open your pie-hole at the worst possible time, it might even get you killed in real life. Talking shit doesn't work against people with intelligence, just so you know.
EchoHoLiK is offline   Reply With Quote
Old 06-24-2006, 08:57 PM   #9 (permalink)
That Acura Guy
TTercel's Avatar
Gameroom cash: $267565
View TTercel's Photo Gallery
I dont even consider the S2000 as a sports car. To race that car you have to say in high revs or else if you come down too low it just falls on its ass. I have even heard some where where a stock S2000 was dynoed and only made 175whp, I have no proof of that but its what i have heard. Who would spend $50,000 on roadster civic...? End of my rant sorry for going off topic.
Why in that magizine does it say that the Celica redlines at 7800rpm i thought it was 8400rpm
TTercel is offline   Reply With Quote
Old 06-24-2006, 09:30 PM   #10 (permalink)
Moderator
Celica GTS 00,01, 03 - 04 (drive by wire) had a redline at 7800 rpm and revlimited at 8400 rpm just like the XRS, but the XRS redline is at 8250 rpm. The 02 and 05 model GTS were revlimited at 7800 rpm.
Old 06-24-2006, 11:41 PM   #11 (permalink)
Always on the Warpath--->
xrs22's Avatar
View xrs22's Photo Gallery
Here, check this out for some visual stimulation.
http://www.toyota-europe.com/innovat...nes/vvtl_i.asp
xrs22 is offline   Reply With Quote
Old 06-25-2006, 07:46 AM   #12 (permalink)
2005 Corolla XRS
357wheelgunner's Avatar
View 357wheelgunner's Photo Gallery
Type like an adult and it woudl be easier to respect what you have to say.
Your "homie" is racing stock 1zz corollas probably, or celica GT also with 1zz motor.
The B16 is a great motor, with stronger internals and a raised redline (I'm talking 10K rpms here) it is amazing, but short of spending thousands of dollars on it there is really nothing special about the B16, or any other B series motor. Even the famed Integra GS-R is no faster than a stock XRS, they are dead even in any and all tests and respond equally well to mods, the only dfiference being more mods available for the GSR because it is a honda with VEEETECCCC which means it is sooooo fast and cool
VTEC is completely different and can't be compared. The Toyota motor does what VTEC does, and more, all with much less weight due to a more efficient system.
Remember ricers, just because one car is more popular does not mean that it performs better. I'll take the 4 door that everyone thinks is slow but runs low 15s stock and has dirt cheap insurance, than a fricken honda coupe that runs 17s and has high insurance.
Your Honda S2000 has nothing to do with this conversation, you wasted more than 30K on a fricken honda miata lookalike girl car. Enjoy it....
2005 Corolla XRS
Vibrant exaust, 30% tint, K&N Short Ram Intake, HKS grounding kit, ES motor mount inserts, TRD Springs, Koni Yellow shocks
357wheelgunner is offline   Reply With Quote
Old 06-25-2006, 07:50 AM   #13 (permalink)
2005 Corolla XRS
Originally Posted by silver04rollas
l
I dont think it s a fair comparrison, the type R is heavily modified from the factory, and costs 50% more than the celica GTS.
Mod for mod the GTS would eat the integra alive....
2005 Corolla XRS
Old 06-25-2006, 08:42 PM   #14 (permalink)
Banned
all u punk bitches aint nuttin but haters with ur fuken mini vans thinking yall Jdm? hahaha fuck ur mini van! i will still smoke all ur gay ass soccer mom wagons and my s2k was not 30k for the retards that jump to conclusions, it was 20 with taxes cuz i got hook ups so shut the fuck up, and whoever says "i'll get 'killed' for talking like this", foo shut the fuck up whitey cuz yo ass dont even know what its like to be living in the hood homie. if ur ass came to my hood we would fuken strip ur cheap ass wagon and blast ur ass so shut the fuck up cuz u know nutting bout being hood fuken eminem... have a wonderful day bitches. VTEC
Old 06-25-2006, 08:51 PM   #15 (permalink)
Banned
btw that stupid video just shows headlights, and all the comments talk shit bout the whack ass corolla family car!! and the idiot who thinks the s2k puts out 175 and has no proof, shut the fuck up, u nosey mutherfuker if u cant back up ur statement stay outta dis son. overall, honda will always smoke toyota the only toyotas i respect are the ae86, levin, and the mr2 turbo and supra, any other wagon or fuken family car (corolla) can eat a fat dick. well i leave it at that levas, have a wonderful day.
