NE1 Changed XRS brakes themselves? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-02-2006, 01:34 PM   #1 (permalink)
Damage_Inc's Avatar
View Damage_Inc's Photo Gallery
Has anyone here changed their brakes themselves on an XRS?
I am putting a Kit on a friends '03 and need to know how you removed the front rotors?
There is a 12pt nut that has been punched into the keyway to keep it from backing off,I'm wondering what's the best way to remove this?
I have searched through some of the online repair manuals posted here but there is no reference as to how to remove the nut.
Thanks,
~Damage Inc
Damage_Inc is offline   Reply With Quote
Old 07-04-2006, 11:21 PM   #2 (permalink)
View mikes_matrix's Photo Gallery
Canada
you dont need to remove that nut
you just need to remove the wheel ( 5- 21mm nuts)
remove the 2-14mm bolts for the caliper .......actually you can just do the bottom one and piviot the caliper up and slide the slider out of the carrier
next remove the 2 - 17mm bolts that hold on the carreier on
if you are not reuseing the rotors....
then take a hammer to the back side of the rotor hit it hard then turn it 120 degrees repeat until the rotor is off
If you are sending the rotors to be Machined .........then use a dead blow hamer or a soft face hammer ...
or use a peice of wood againinst the rotor and use the hammer against the wood to knock the rotor off
where in TO are you ???
MIKE
mikes_matrix is offline   Reply With Quote
Problem bleeding brakes on 95 Camry soonergn 3rd & 4th Generation (1992–1996 & 1997–2001) 32 01-19-2011 11:47 PM
Noobie with XRS Questions lenshead Archived Corolla threads 12 10-29-2005 09:39 AM
No Brakes!!! Need Help!!! csm672 Pre-88 Toyota Pickup/Hilux 3 09-29-2005 06:22 PM
New brakes? CrawlingEye Camry & Solara Lounge 20 03-22-2004 12:14 AM
Just changed my brakes... rayray Camry & Solara Lounge 2 12-02-2002 12:10 PM
