Automatic transmision fluid level check - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2006, 12:26 AM   #1 (permalink)
View skugelstadt's Photo Gallery
I looked in the Matrix manual and cannot locate any reference on how to check the auto trans fluid level. Most of my vehicles had manual transmissions so I am a little lost. Should the engine be running? Transmission oil hot/cold? I have the 130 HP engine if that makes a difference. Thanks. Also are there any inexpensive service/repair manuals published. I searched for Haynes and Chilton but no luck. Stuart
skugelstadt is offline   Reply With Quote
Old 07-15-2006, 02:57 AM   #2 (permalink)
View toyomoho's Photo Gallery
If the transmission has a dipstick, the fluid is normally checked with fluid hot, engine at idle and running the gear selector from Park to Low and back. Then with engine at idle check use the Hot marks on the dipstick.
The cold marks (if applicable) can be used for refilling the transmission after an oil change by doing the same procedure above.
Do not overfill the transmission.
Old 07-18-2006, 05:49 PM   #3 (permalink)
Transmission
Thanks much for the response, it's appreciated. Stuart
Trans/diff fluid question - '96 LE 2.2L w/A140E Truthunter 3rd & 4th Generation (1992–1996 & 1997–2001) 11 12-05-2007 01:22 PM
2000 Camry Auto trans fluid WEFs00 3rd & 4th Generation (1992–1996 & 1997–2001) 15 01-28-2007 09:25 PM
servicing at 77k bowlofturtle Camry & Solara Lounge 5 06-19-2004 09:29 AM
Brake Fluid Level warning switch Zer05 Camry & Solara Lounge 5 11-12-2003 11:09 PM
Maintenance 90CamryDx3SFE Camry & Solara Lounge 6 10-28-2003 09:42 AM
