2003 Matrix help - what is this squeaking? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-20-2006, 12:40 PM   #1 (permalink)
View wvgirl's Photo Gallery
I have a 2003 Matrix XR.
I have noticed the past ewek that my car is squeaking....As soon as I turn it on it starts and the pitch changes when I apply the gas. Could this be the serpentine belt?? If not, what does it sould like to you?
Anyone replaced one before?? Can you do it without taking out the engine or should I just take it to the mechanic?
A little background...got it in May 2002 and it has 54,000 miles.
Thanks!
wvgirl is offline   Reply With Quote
Old 07-20-2006, 04:26 PM   #2 (permalink)
View MatrixXRS's Photo Gallery
Once you're warmed up and the squeaking is gone? if so, it's the serpentine belt. Replacing it would take less than 30 minutes and no engine remove is required .
MatrixXRS is offline   Reply With Quote
Old 07-21-2006, 07:47 AM   #3 (permalink)
No, the noise doesn't go away when the engine is warmed. It does this all the time. I noticed it a couple of weeks ago...it would only squeak when it was humid or had just rained....now it does it all the time.
Old 07-21-2006, 01:55 PM   #4 (permalink)
Frank@toronto's Avatar
View Frank@toronto's Photo Gallery
I wonder if your AC compressor is seezing up?
Does it still happen when your AC is OFF (and your cabin selector, that dial thing next to your hot and cold selector, is not pointing to the window options).
Could be the belt tensioner also...
Frank@toronto is offline   Reply With Quote
Old 07-21-2006, 09:09 PM   #5 (permalink)
View trxr's Photo Gallery
Get ALL your belts checked.
trxr is offline   Reply With Quote
Old 07-21-2006, 09:15 PM   #6 (permalink)
That could be possible and if thats the problem, you will have to buy a new one. At $500, plus the cost of installiation, they are not fun to fix.
Old 07-22-2006, 10:05 AM   #7 (permalink)
OooThatsSharp's Avatar
View OooThatsSharp's Photo Gallery
This is, unfortunatly, a pretty common problem for the Matrix. Our belt tensioner is weak. Take it to the dealer, and have them inspect the belt and tensioner. Or, you can try to DIY. Check out matrixowners.com and search for squeaky belts, and you will find the DIY fix for the tensioner. Best of luck.
OooThatsSharp is offline   Reply With Quote
Old 07-22-2006, 10:09 PM   #8 (permalink)
TRXR4KDS's Avatar
View TRXR4KDS's Photo Gallery
I finally took mine into the dealer and they replaced the belt under warranty. NO more squeeking when it's rainy, damp or humid.
TRXR4KDS is offline   Reply With Quote
Old 01-29-2007, 01:16 PM   #9 (permalink)
View Javert's Photo Gallery
I have seen that alot of times it is just the belt tensioner pulley bearing worn out. If the tensioner is in good shape, I would recommend replacing the belt tensioner pulley and go with a Goodyear Gatorback belt! That is just my two cents worth.
Javert is offline   Reply With Quote
2003 Matrix XRS concerns before buying... NeatO 1st Generation (2003-2008) 12 01-26-2005 09:28 PM
Pictures of my Mom's 2003 Matrix Hotwheelharmer 1st Generation (2003-2008) 2 06-24-2004 07:21 PM
Toyota Matrix XRS VS 2003 Honda CRV EX Fred Garvin 1st Generation (2003-2008) 4 05-22-2003 09:33 PM
