amp grounding - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-04-2006, 06:06 PM   #1 (permalink)
View NoamHassid's Photo Gallery
amp grounding
I am installing a single MTX in my friends matrix. Everything is set up except for where to connect the ground wire. i can connect it directly to the chassis. ive got enough wire to make the connection. Just need to know where the best spot is.
NoamHassid is offline   Reply With Quote
Old 08-05-2006, 02:41 PM   #2 (permalink)
OooThatsSharp's Avatar
View OooThatsSharp's Photo Gallery
When I installed my amps, I removed the rear seat, and used a drill to create a "fresh" ground point. I know of some people who have just used some existing bolts in the back with success, but nothing beats a "fresh" ground, right to the body of the car.
OooThatsSharp is offline   Reply With Quote
Old 08-09-2006, 12:43 PM   #3 (permalink)
thnx. i found a hole through to the chassis next to the spare.Thnx though for the reply.
Old 01-02-2007, 01:16 AM   #4 (permalink)
Klaatu barada nikto
View spin156's Photo Gallery
I installed my amp under the passenger seat. In the process of pulling up the rug to run wires I found an unused bolt hole in the chassis and used it. It was already threaded, so I just sanded down to bare metal and used a ring washer under the bolt head. It was nice, as the resulting cable to my amp was less than a foot long ;-)
spin156 is offline   Reply With Quote
Old 01-02-2007, 11:40 AM   #5 (permalink)
SiLLy R@bbit's Avatar
View SiLLy R@bbit's Photo Gallery
if you do this i suggest you silicone both the top and underneath of the screw/bolt, the rear floor is very thin and rusts pretty quick, mine lasted less then a year before i had to redo it.
SiLLy R@bbit is offline   Reply With Quote
Old 01-02-2007, 01:25 PM   #6 (permalink)
Klaatu barada nikto
I actually found a boss that was welded to the floor (similar to the mounts for the seat rails). It did not go through to the outside of the car, so I don't think rust will be a problem.
amp wire for grounding engine? GeRm0MR2 Hardcore Tech and Competition 2 10-03-2004 04:21 PM
hyper grounding your amp? tightcamry129 Audio, Video, and Security - Tech 0 03-20-2004 06:43 AM
