thanks to MR. TRDMatrix-Eh by sharing the info regarding the LOTUS ELISE...been wanting to get one and i thought i was going crazy when I found out that XRS and Elise shared the same engine...that's make it even better! the only negative review about it is the comfort after a long drive (but who would take it for a long drive if it's designed to be on track,right?) and the mileage per full tank (it only has 10.9 gal. capacity) Below is the LOTUS ELISE spec...
Can't say "LONG LIVE the XRS" coz' didn't get a chance to own one but I would say...enjoy your XRS while it last
Exterior
• Cast Alloy Wheels, 8-Spoke
Yokohama Advan Neova AD07 Tires
Front: 5.5J x 16 – 175 / 55 R16
Rear: 7.5J x 17 – 225 / 45 R17
• Power Assisted 4 Wheel Ventilated / Cross Drilled Disk Brakes
• Lotus / AP Racing & Brembo Calipers with Anti-Lock Braking System (ABS)
• RTM Composite Fiberglass Body
• Black Cloth Soft-Top
• Rear Diffuser with Central Twin Exhaust Interior
• Air Conditioning
• Airbags – Driver and Passenger (passenger airbag cannot be deactivated)
• Alarm System with Remote Locking
• Central Door Locking
• Separate Starter Button
• Seats – Cloth/Leather Trim
• Aluminum Trim – Gear Knob, Handbrake Sleeve, Manual Window Winders
• Leather-Trimmed Steering Wheel
• Black Floor Mats
• RDS Radio and Single CD-Player with 4-Speaker Sound System
• Intermittent Windshield Wiper
• Tinted Glass
Engine Specification
• Toyota Supplied, 1.8 liter 4-Cylinder with DOHC, 4 Valves Per Cylinder, Variable Valve Timing and Lift Intelligence (VVTL-i)
• Capacity 1796 cm3
• Bore/Stroke 82.0 mm / 85.0 mm
• Maximum Power 190 hp (141 kW)
@7800 rpm (DIN 70020)
• Maximum Torque 138 lb ft (181 Nm)
@6800 rpm (DIN 70020)
• Compression Ratio: 11.5 : 1
• Fuel Tank Capacity 10.5 US Gallons Transmission
• 6-Speed Close Ratio with Single-Plate Dry Clutch.
Ratios:
• First: 3.17:1
• Second: 2.05:1
• Third: 1.48:1
• Fourth: 1.17:1
• Fifth: 0.92:1
• Sixth: 0.81:1
• Reverse: 3.25:1
• Final Drive: 4.53:1
Chassis / Suspension
• Lotus Designed Lightweight Structure of Epoxy Bonded Aluminum Extrusions
• Integral Steel Seat-Belt Support Structure and Lightweight Steel Rear Sub-Frame
• Fully Independent Suspension with Unequal Length Wishbones
• Bilstein Mono-Tube Gas Damper
• Eibach Coaxial Coil Spring
• Front Anti-Sway Bar Performance
• 0-60 mph 4.9 seconds
(4.7 sec, Sport Pack)
• 0-100 mph 12.9 seconds
• Top Speed 150 mph
• 0 - 100 mph - 0: circa 17.5 sec
• 100 mph - 0: circa 85m
• Fuel Consumption EPA 23 City / 27 Highway
• Curb Weight Base Car 1984 lbs
